1 - 8 of 8 Posts
I found these 2 unplugged cables in my "new" 2015 Volt. Any idea what they are and where they go?
Also What computer is under the dash , to the left of the brake pedal? it looks like someone has done some work to it in the past and i have no idea what its for.
Thanks!
2015 Red Volt
Thanks!
Those are coaxial cables, I would assume for XM radio and GPS antennas. No idea what the empty socket is for.
if GPS and XM then some how the cable path need to get to the head liner and to the roof antenna.
By "new", do you mean new to you but previously owned? If so the coax could be for an aftermarket subwoofer that has been removed.
I've taken out my 2013's radio several times, it doesn't have any connectors quite like that. It does have some coax connectors, but they were different... either 2015 changed or those are some aftermarket stuff that has been removed.
OP, does everything work in your car? XM/AM/FM etc?
Yes "new" to me, i got the car in an auction, so i have very little history on it.
Everything appears to work fine, AM/FM/XM all work. I just find it troublesome to have 2 cables that go no where.
1 - 8 of 8 Posts
