1 - 10 of 10 Posts
Good to know.
drivers door window doesn't roll up automatically
There is a procedure to reset the window sensor, I don't recall what it is for the Volt, maybe roll window all the way down and back up and hold the up for 5 seconds after the window closes, or maybe that is for my Nissan. Check in the owners manual.
Yep, the manual has the answer you are looking for, assuming switch is not faulty, whenever the 12 V is disconnected you might need to reset express window operation.
I haven't decided whether voltzz is a spammer in the making yet. All three posts have been very short and a bit cryptic.
The Death Star plans are not in the main computer... It has almost the exact same syncopation.
The driver's window switch is a double detent on my 2011 gen1, you can get it to roll up if you pull the switch all the way up and hold it for a second.
1 - 10 of 10 Posts
