A few weeks ago I noticed that I was getting an intermittent squeaking coming from my left rear brake. I didn't think much of it at first, as many brake squeaks are nothing big. A few days later I noticed it was squeaking for my entire commute home, and when I got out that brake rotor was very hot, while the other 3 were cool.
Fast forward 2 weeks as I was travelling with the Volt parked, and I finally got around to addressing the issue.
I jacked up the rear end and it was relatively difficult to turn the wheel by hand. I figured the caliper must be seized, so I went and grabbed a new caliper for about $150 at a local parts depot.
Later that night I got around to working on the car. Pulled the wheel off, and then the caliper. Before I went too far I tried spinning the hub again, and I couldn't budge it without extra leverage. The pads themselves were actually seized into the caliper bracket. I then tried to compress the rear caliper (note, a c-clamp or large pliers don't work for the rears. You need large needlenose pliers and you actually screw in the piston rather than squeeze it). It seemed to compress without too much effort, so it seemed the caliper wasn't the issue.
After spending about 10 minutes prying the pads out, I cleaned the dirt out and reinstalled everything. Then I pressed and released the brakes, and ended up with the same results. So took everything back apart, and again pried the pads out. I then took a die grinder and cleaned up and removed a tiny bit of material from one of the tabs at the end of the pads. It seems the pads were just a touch too long to fit into the bracket. After cleaning it up, and coated the tabs with antiseize and again, reassembled everything.
This time after pressing and releasing the brakes, the wheel spun freely. So now I get to return the new caliper and save myself $150!
