1 - 4 of 4 Posts
I have a 2014 Volt and am trying to figure out how to remove the map light lens. Is there a way to get the lens off without disassembling the entire panel the light is part of.
use plastic interior tools,I use the small flat bar,then pry on the right side of the lens and it should pop out.
I second this - the clear plastic comes out, it just takes a little finesse-ing. If memory serves me (I replaced with LEDs about 4-5 months ago) there are two "tabs" on the edge facing the rear of the car that you just need to worry about.
Goty it - Thanks
Thank you for your directions. I was able to get it out using a small screwdriver. I was very careful to not scratch the lens. I found my trim tools to big to get between the cover and the case.
Thanks again,
Bob
1 - 4 of 4 Posts
