No oil level or even oil pressure warning?
2017 Volt approaching 10k miles. About 6 weeks ago the oil life was below 10% and my wife (it's her car) wanted to get the oil changed to be rid of the frequent dash messages. So she called the dealer and the best they could do was 2 weeks out. We work at the same place and a reputable tire chain shop was walking distance so we had them do the oil change. ..... Seemed fine, but 5 weeks later while driving to work the message "Propulsion Power is Reduced" appeared. We had driven separately that day so I wasn't present, but doesn't matter, she saw what she saw (and took a pic) and it was present later when I investigated.
I researched a little and read about the battery being below the desired minimum charge can cause this message .... so when I got a free moment turned the car on and put into mountain mode so that the engine/generator would charge the battery*. After 2 minutes the revs increase significantly and it was vibrating and rattling. A minute later I saw smoke coming from the engine bay. Shut down immediately.
Called dealer, made apt for first thing in the morning. Drove the car 2 blocks to a Whole Foods to charge it so that the drive to drop off at the dealer would be battery only. That evening, upon arriving home I noticed that the parking space had a puddle of oil under where the front of the Volt had been. Pretty sure this was a very fresh event.
Next Day.
Dealer calls informing us that the crankcase oil was empty and it leaked out through the oil filter (Penzoil). The Filter that the shop had used was the correct one but the gasket seal shrunk or failed somehow. I'll add a pic and some info later. I have the filter.
The good news is that after replacing filter and oil etc, no damage had been done and we were only out $225. This was not warranty because a third party's oil filter was the cause. The engine could have been badly damaged and one can only imagine what the cost might have been.
========= getting to the point now
The major question I have is, and I asked the service guy who did not directly answer, why did we not get any message on the dash in any form that indicated that the oil was way low? "Propulsion Power is Reduced" is all we got and is irrelevant and misleading. How about OIL LEVEL TOO LOW, or at least an oil pressure too low warning. To me this is a very serious issue.
Thanks, Bob
*Live in a condo apartment situation, underground parking, no electric outlets, so we are not charging the car daily as most are able to do. Therefore it is at the minimum most of the time.
Next Day.
Thanks, Bob
