With a little over 80K on the odometer and less then 3/32's of tread depth left, it was time for a third set of tires for our 2014 Gen 1. The first change I went with the Pirelli Cinturato P7 All Season Plus and liked them a lot (previous review). I've read a lot of good comments here about the Continental True Contact w/Eco Plus. The Labor Day sales on the Continentals at Discount Tire were good, so I thought I'd give them a try for the second swap. This also gave me the ability to directly compare these two highly ranked tires. Here's what I've learned.
Noise: Both the Pirelli and Continental are light years quieter than the OEM Goodyears. To my wife and I, the new Continentals sound slightly louder than the old Pirellis on worn surfaces and our infamous Texas chipseal highways. Let's hope the Continentals don't get too much louder as the wear down. On smooth pavement they are both as silent as can be. There appears to be a slight whooshing sound from the Continentals when at high speeds (75 to 80 MPH) on smooth asphalt. Booming from expansion joints and road imperfections are muted with both tires. Advantage Pirelli, but not by much.
Tracking. The Pirellis tracked like a champ. Brand new, the Continentals tend to wander a bit on the highway. This might be due to tread squirm, so it may settle down a bit as they age. For now, clear advantage to the Pirellis.
Handling: The Pirellis did very well on dry surfaces, but I felt some slight slip from time-to-time on smooth wet surfaces. Wet handling was the one areas where the Pirelli's needed some improvement IMO. After 48+ inches of rain from Harvey in South East Texas earlier this month, I've thankfully not yet had a chance to take them out in the rain. Advantage: unknown for now.
Construction: The Pirellis served us well. No blowouts, flats, or sidewall issues. Continental is a great manufacture, so I don't expect any issues. I can say that the right, front, Continental took 18 weights to balance it... so that's not good. The Continental's are rated at 800 A B where the Pirellis are 700 A A, so take that for what it's worth. Advantage: unknown for now.
Range: I ran the Pirellis at 42 to 44 PSI and once broken in, my range was almost identical to the OEM Goodyears. We're too early to tell where the Continentals will go, but others have reported good range. I've settled in to about 40 PSI for now. The Continentals max at 44 PSI, so there's not a lot of headroom to go higher (Pirellis maxed at 51 PSI, if I remember). Advantage: unknown for now.
Price: The Continentals were $19 less per tire and came with a $70 rebate. That made them $146 less than the Pirellis on the day I purchased. An extra $200 off from Discount Tire made the overall deal even better. Advantage Continental.
Overall: We're still too early to say. Right now, I'd give the overall advantage to the Pirelli Cinturato P7 All Season Plus. Are they worth the extra $146 (which was ironically the cost on one Pirelli Cinturato P7 tire), I'm not sure yet. Both are very good and the Continentals are 25% less. If the range comes comes back and the tracking gets better, then I'll be very happy.
Hope this helps.
Hope this helps.
