I am not the type to never want my engine to come on at all. I realize that burning a little gas can be more efficient than trying to use electricity to get the cabin comfortable when it's less than 20 degrees outside. On most occasions, I view this as a benefit of owning a PHEV, not a hindrance.
However, I've noticed recently that under about 17 degrees Fahrenheit, the engine will come on no matter what and run constantly for about 10 minutes (as opposed to on and off hybrid operation in hold mode), until the coolant temp gets up to about 180. During this cycle, it consumes about 0.20 gallon of gas according to the energy display, and I usually end up recording about 10-20 MPGcs on short trips.
Again, I have no problem with this if it's used to "kick start" the heat on a half hour or longer trip, but if I'm running 10 minutes down the road to grab bagels or go to the hardware store or whatever, I feel like I'm running the gas to heat up the cabin on a trip that's not even long enough to heat it, and by the time I get done with my errand, my cabin is cool again and the engine runs due to temperature again while I'm driving home.
By the time I get home, I've burned between 0.2-0.4 gallons of gas over just 5-10 miles total, I didn't drive long enough either way to really benefit from the heat, and my miles per gallon score is awful.
My engine assist heat setting is already on deferred. I realize this is small potatoes in the grand scheme of owning the Volt, but I feel like I should be able to tell the car "no, don't do this, I'm happy enough being cold for the next 5 minutes of my life." Frankly, it's odd to me that this setting runs even before I turn the heat on.
Any suggestions -- I'm not looking to tear my car apart and install a defeat device. Just wondering if there's something I can do to sort of trick the Volt out of ERDTT mode when I'm taking a short trip.
