Well, it took me a few months to get around to it, but I have resurrected my Coulomb/ChargePoint CT500. Again.
It was indeed the power supply. Mine was completely dead, instead of having a wandering voltage where the CT500 shows some life but doesn't behave correctly.
The
AEVA post discusses power supply details. It's made by TDK-Lambda and is supposed to be medical-grade super reliable, but they seem to be the opposite of reliable. They're also expensive. I decided I didn't want to spend that much for an exact replacement.
The blue rectangle in this image is the bad TDK-Lambda power supply:
My soldering skills are pretty weak, so I decided I didn't want unsolder it from the PCB. (Side benefit, I didn't have to unscrew the PCB from the metal plate.) I decided instead to try to cut it out with a dremel tool. This was time consuming and made a huge mess. It didn't come out cleanly, but I had to cut out and remove small bits at a time. But I eventually succeeded.
I was left with only the bottom plastic bit of the power supply, with four metal posts protruding. I was hoping (and later confirmed) that the four metal posts were two A/C inputs and two D/C outputs. In this picture you can only see three of the posts, because I took a chunk of the crumbly insulation stuff and embedded the top-right post with it. (I was originally thinking I'd power the replacement power supply external to the PCB, but then changed my mind.)
Here I've attached four white springy connector things to the four posts. I have never used these before, and I'm not super confident in them. (I think it would be better to use screw-tightened connectors, but I didn't have any. Or to solder the wires to the posts and cover with heat-shrink tubing. I did try using wire nuts, but the posts didn't extend far enough for them to bite.) Not shown in the picture are four pieces of insulator tubing, which I used to surround the four white springy connectors.
Here the purple and white wires are the two A/C inputs to the new power supply. (White is marked Neutral and purple is marked Line, but since this will be plugged into a standard USA 220 circuit, both will be hot.) I didn't have the new power supply yet so, to avoid shocking myself, I temporarily capped the end of these two wires with wire nuts.
The yellow wire is D/C +5V. The blue wire is D/C ground. I figured I had a 5V D/C power supply in my house somewhere I could use to test, but had trouble finding one. I eventually found the power brick that came with an old Belken USB 1.x hub. It outputs 5VDC at 2.3A but, unlike most modern power supplies which can handle 120V and 220V just fine, this one's A/C input isn't supposed to go above 120V.
So I plugged the Belkin power brick into a regular 120V circuit, jury-rigged a connection to the yellow/blue wires, and it came back to life!
I should mention that I gouged out a small section of grey plastic cover for the four wires to go through, so they wouldn't be pinched too much.
This was good enough to charge my vehicle. I plugged the CT500's cord into 220V, and also used an extension cord to plug the Belken power brick into 120V.
So far so good. Now to give it a real power supply.
I decided I wanted to buy a Mean Well RS-25-5 power supply, which accepts 88–264 VAC and outputs 5VDC at 5A. You can find one for less than US$20.
But I accidentally bought a Mean Well RS-15-5 instead, which is similar but outputs 5VDC at 3A, not 5A. That should be good enough. The original TDK-Lambda KMS15-5 also outputs 5VDC at 3A. And I have disconnected the 2G cellular modem from power anyway, so it probably doesn't even need the full 3 amps. The Belkin power brick was 2.3 amps.
Here is the Mean Well RS-15-5, pictured next to a block of styrofoam that I had cut to approximate the size of the RS-25-5. (The RS-15-5 is slightly smaller than the RS-25-5, 63Ă—51Ă—28 mm vs. 78Ă—51Ă—28 mm. Both are 5mm wider than the original TDK-Lambda unit, which was 64Ă—46Ă—24 mm.)
Here it is installed in the CT500.
And here it is back on my garage wall, charging my vehicle. (No 120V power brick and extension cord this time.)
It's only been five hours, but so far it works fine. My car has completed charging.
Hopefully I don't regret using those white springy connector things. My CT500 has already died three times. I shouldn't be surprised if it dies a fourth time.
With the outer cover back on, it looks the same as it always has:
