As mentioned elsewhere, it is a requirement for Bolt dealers to purchase a DCFC charger for the service department.
Although they will likely be used to routinely charge Bolts in for service, they are mostly necessary in order to insure that they are in a position to be able to test and if necessary diagnose DCFC issues.
The unit itself is interesting as it is a 25kW unit from Bosch which only requires a 240V single phase input (albeit with a service rated to handle a maximum of 138A input current)
The 24x18x10" enclosure is IP54 rated, can be wall or pedestal mounted and weighs 104lbs
WOT
WOT
