1 - 4 of 4 Posts
I've been enjoying my DashDaq XL for a while now, and with baby#2 on the way, have to think about selling some toys. Thought I'd see if anyone was interested in throwing an offer my way.
This is the unit: http://www.rivercitydiesel.com/inde...uct_details&product_id=290&vmcchk=1&Itemid=54
Videos:
My actual unit: https://www.youtube.com/watch?v=1jIo4OE2Yww (some of the labels I didn't know at the time are defined by the list below)
Some other guy with other customized screens: https://www.youtube.com/watch?v=M6ssU278Uk0
Thanks,
Brant
Discussion Starter · #2 ·
oh, and of course it has the Volt license and all the items below available for monitoring:
Accelerator Pedal Position
Accessory Power Module Current
Accessory Power Module Voltage
Air Conditioning Compressor Power
Air Conditioning Compressor Power Limit
Air Conditioning Compressor Speed
Air Conditioning High Side Refrigerant Pressure
Air Conditioning Low Side Refrigerant Pressure
Air Conditioning Low Side Refrigerant Temp
Ambient Air Temp
Auto Stop Inhibit: Too Much Time Since Vehicle Stop
Auxiliary Transmission Pump Motor DC Current
Auxiliary Transmission Pump Motor DC Voltage
Auxiliary Transmission Pump Motor Inverter State
Axle Torque (Actual)
Cabin Climate Control Power Cmd
Charge Coupler Proximity Voltage
Commanded Immediate Engine Torque
Commanded Throttle Position
Control Module Voltage (ECM)
Distance Traveled on Battery Energy This Drive Cycle
Driver Intended Axle Torque
Driver Intended Brake Torque
Energy Storage System Charging Power Limit
Energy Storage System Coolant Pump Spd (RPM)
Energy Storage System Coolant Valve Cmd
Energy Storage System Heater Cmd
Engine Actual Steady State Torque
Engine Coolant Temperature
Engine Speed
Filtered Long Term Fuel Trim Bank 1
Filtered Long Term Fuel Trim Bank 2
Filtered Short Term Fuel Trim Bank 1
Filtered Short Term Fuel Trim Bank 2
Front End Cooling Fan Spd Cmd (ECM)
Front End Cooling Fan Spd Cmd (VICM)
Fuel System Status: DFCO Active
Fuel System Status: Fuel Trim Learned Enable
Heater Core Coolant Valve Cmd
Heater Core Coolant Valve Position (%)
High Voltage Battery Average Temp (HCP)
High Voltage Battery Average Temp (VICM)
High Voltage Battery Current (HCP)
High Voltage Battery Current (VICM)
High Voltage Battery Fan Speed (RPM) (HCP)
High Voltage Battery State of Charge Gauge Position
High Voltage Battery Voltage (HCP)
High Voltage Battery Voltage (VICM)
Hood Switch Position
Hybrid Auxiliary Fan Spd (RPM) (VICM)
Hybrid Battery Discharge Current (HCP)
Hybrid Battery Max Module Voltage (HCP)
Hybrid Battery Max Temp (HCP)
Hybrid Battery Min Module Voltage (HCP)
Hybrid Battery Min Temp (HCP)
Hybrid Battery Pack Remaining Charge
Hybrid Battery State of Charge (HCP)
Hybrid Battery Voltage (HCP)
Instantaneous Fuel Consumption
Intake Air Temperature
Intake Manifold Absolute Pressure
Motor A DC Current
Motor A DC Voltage
Motor A Inverter State
Motor A Speed
Motor B DC Current
Motor B DC Voltage
Motor B Inverter State
Motor B Speed
On Board Charger AC Input Current
On Board Charger AC Input Voltage
On Board Charger High Voltage Output Current
On Board Charger High Voltage Output Power
On Board Charger High Voltage Output Voltage
On Board Charger Low Voltage Output Current
On Board Charger Low Voltage Output Power
On Board Charger Low Voltage Output Voltage
On Board Charger Temperature
Power Electronics Coolant Loop Temp (HCP)
Power Electronics Coolant Loop Temp (VICM)
Power Electronics Coolant Pump Spd (RPM)
Regen Braking Axle Torque (Estimated)
Spark Advance
System Power Mode
Total AC Energy Used During Last Charge
Total HV Energy Used During Last Charge
Total LV Energy Used During Last Charge
Transmission C1 Clutch Slip
Transmission C2 Clutch Slip
Transmission C3 Clutch Slip
Transmission C4 Clutch Slip
Transmission Clutch Pressure
Transmission Fluid Temp (ECM)
Transmission Fluid Temp (TCM)
Transmission Gear or Mode Achieved
Transmission Input Speed
Transmission Line Pressure Current
Transmission Output Speed
Transmission Ratio
Transmission Torque Converter Slip
Transmission Turbine Speed
Vehicle Speed
1 - 4 of 4 Posts
