Thanks, this is really good stuff. I was sold before but now I must have one.
You might want to hold your horses *just* a little bit. I've got a
MAJOR beef with them about their unit, how they advertise it, and how it performs.
Specifically, the Volt "Extension" isn't an extension at all. You can either have all the generic OBD scanning codes, plus the GM extensions
or you can have the Volt "extensions". Loading up the Volt driver excludes any other J1962 drivers (which includes ALL the other OBD drivers they seem to have).
So if you're interested in Volt-special type stuff, you can't see any of the things you'd normally expect to see with any other car. If you operate 100% EV, that's not too much of a problem. But if the ICE turns on, about the only things you can see are RPMs, Torque, and coolant temps. Specifically, there's no way to estimate instantaneous MPGs, as the MAF isn't available and there's absolutely no way to estimate it.
And that's a biggie for me.
So while this is neat stuff, I in absolutely
no way can recommend the DashDAQ at this time.
It doesn't help that I identified this problem as critical when I first bought it nearly a month ago, they agreed it was a problem and said they'd work with me to find a resolution. Since then? *crickets*
If I don't hear something soon I'll likely be contesting the charge on the credit card for false advertising, and sending the unit back.
[later edit:] I'll also note that when I complained to Drew Tech (the makers of DashDAQ) that the unit panicked with 24 dials on the screen, they said the most gauges that could be put on the screen is 24 (since that's the most any of the provided skins uses). This video shows 20 analog gauges on the screen, plus 11 digital gauges, 4 buttons, and a text box. The skin editor tool doesn't like this much more than the unit itself does, and support there seems pretty shaky as well. None of their demo skins uses overlaid analog gauges. This displays up to 8 analog gauges overlaid onto a single dial. I honestly don't know what they're going to think about that, either.
