1 - 20 of 95 Posts
When I was at the Volt's homecoming event in Detroit last week a Volt engineer suggested I try the DashDaq data acquisition/display computer. Has anyone tried it? I already ordered it from Amazon but they haven't shipped it yet so I should be able to cancel. From what I understand it is very cool and it gives you over 400 data point and sensor inputs. I would like to get specifics on engine RPM, regen values etc. Apparently Drew Technologies have a Volt specific software package (for an extra $95!).
If I don't get any feedback soon then I will provide some later in the week if I get it soon!
Gordo
Super Moderator
Discussion Starter #3
Ok, got it today and WOW!
It is picking up almost 200 parameters and the display is very nice. I bought a sticky disk from Radio Shack and can mount it with the suction cup to the left of the primary display screen (behind the turn signal lever) and can route the cable in the door seal. I am still playing with what sensors give me what information but so far I am impressed. I also have to play with the different themes since each theme has a different number of gauges and data value boxes. I also like being able to record timeline information on an SD card.
I did have to buy the Volt licensing to get all the information but the inner engineer in me is very happy now!
Do they have an on-line user's manual? What sort of info is available in the on-line customer support area?
Discussion Starter #7
Does it display the state of battery charge and kWhs used/remaining since last full charge?
Yes it does. There are about 15 parameters just for the high voltage battery alone! I will need too look and see which one will give you kWhs used/remaining since last charge (some of the data inputs are a little cryptic.) One piece of info that I found interesting so far is how and when the secondary motor is clutched into use. The main motor (B) will hit over 6000 RPM then if there is little torque change the other (A) motor starts being used and the RPM on the B motor drops by half. Also, it look like during regen the B motor is clutched again to increase RPM. Amazing that all this is going while being TOTALLY transparent to the driver. I have a lot to learn still about the inputs and the data.
Gordo
Discussion Starter #10
The price is $549 without the GPS nav feature and the Volt license is $95. I bought mine through Amazon which saved $15 and it was delivered through TunerTools. The Volt license is not on their website yet so I had to call and do it over the phone which was quick and easy.
Question: from their website they make no mention of a "Volt License", just a "GM enhanced" license. Is it necessary to ask specifically for a Volt license or would a GM license include the Volt parameters?
Discussion Starter #12 (Edited)
The Volt license has to purchased over the phone by calling Drew Technologies.
The GM license is for all other GM cars but does not have the parameters specific to the Volt. I asked them if the Volt license will work on other GM cars and the answer was no. However, the installed generic parameters database should give anywhere from 30-60 parameters (with 60 for 2010 and newer cars) and should give most non-Volt car owners everything they need unless they want to do advanced troubleshooting on their own.
I am also tinkering with their custom skin builder so I can have gauges and data fields that are custom for the volt. If I can come up with something better than the built-in skins, I will let you know.
You can see the installation in my Volt and keep in mind that I shot these with a large body pro digital camera and the lens is well below eye level so, when seated normally, the steering wheel does not obscure the screen at all:
Here are the Volt parameters:
ashDAQ Available Signals Report
Time: Wed Oct 13 14:27:10 2010
Firmware Version: DashGUI-2.1.4-2024
Device: a-GM Specific (volt) Version:2.1.4-2024 (Base)
9998 "Latency" "OBD Latency" "ms" 0
9999 "Updates" "OBD Update Rate" "Hz" 0
1586 "APP" "Accelerator Pedal Position" "%" 0
1573 "APM Crnt" "Accessory Power Module Current" "A" 0
1569 "APM Temp1" "Accessory Power Module Temperature 1" "°C" 0
1570 "APM Temp2" "Accessory Power Module Temperature 2" "°C" 0
1574 "APM Volt" "Accessory Power Module Voltage" "V" 0
1549 "ACCM Pow" "Air Conditioning Compressor Power" "kW" 0
1507 "ACCM PowLim" "Air Conditioning Compressor Power Limit" "kW" 0
1548 "ACCM Spd" "Air Conditioning Compressor Speed" "RPM" 0
1604 "AC HSP" "Air Conditioning High Side Refrigerant Pressure" "kPa" 0
1547 "AC LSP" "Air Conditioning Low Side Refrigerant Pressure" "kPa" 0
1552 "AC LST" "Air Conditioning Low Side Refrigerant Temp" "°C" 0
1564 "Amb Air Tmp" "Ambient Air Temp" "°C" 0
1594 "AuxPmp Spd" "Auxiliary Transmission Pump Speed" "RPM" 0
1581 "Axle Tq" "Axle Torque (Actual)" "Nm" 0
1584 "Axle Tq Immd" "Axle Torque Commanded (Immediate)" "Nm" 0
1580 "Axle Tq Pred" "Axle Torque Commanded (Predicted)" "Nm" 0
1509 "CHCM Cmd" "Cabin Heater Power Cmd" "kW" 0
1508 "CHCM Req" "Cabin Heater Power Req" "kW" 0
1544 "Proximity" "Charge Coupler Proximity Voltage" "V" 0
1603 "TPS" "Commanded Throttle Position" "%" 0
1563 "HCP Mdl Vlt" "Control Module Voltage (HCP)" "V" 0
1562 "DistTravl CC" "Distance Traveled Since Code Clear" "Km" 0
1560 "MIL on Dist" "Distance Traveled with MIL On" "Km" 0
1585 "Total Axl Tq" "Driver Intended Axle Torque" "Nm" 0
1583 "Total Brk Tq" "Driver Intended Brake Torque" "Nm" 0
1554 "ESS AC Cmd" "Energy Storage System AC Comp. Power Cmd" "kW" 0
1553 "ESS AC Req" "Energy Storage System AC Comp. Power Req" "kW" 0
1512 "ChrgngPowLim" "Energy Storage System Charging Power Limit" "W" 0
1610 "ESS CondReq" "Energy Storage System Conditioning Mode Req" "" 0
1611 "ESS CondStat" "Energy Storage System Conditioning Mode Stat" "" 0
1527 "ESS Pmp Cmd" "Energy Storage System Coolant Pump Cmd" "%" 0
1515 "ESS Pmp" "Energy Storage System Coolant Pump Spd (%)" "%" 0
1528 "ESS Pmp Spd" "Energy Storage System Coolant Pump Spd (RPM)" "RPM" 0
1607 "ESS Vlv Cmd" "Energy Storage System Coolant Valve Cmd" "" 0
1608 "ESS Vlv Pos" "Energy Storage System Coolant Valve Pos" "" 0
1511 "ESS Htr Cmd" "Energy Storage System Heater Cmd" "kW" 0
1541 "ESS Htr Cmd" "Energy Storage System Heater Cmd (%)" "%" 0
1510 "ESS Htr Req" "Energy Storage System Heater Req" "kW" 0
1505 "ESS Inlet" "Energy Storage System Inlet Temp" "°C" 0
1506 "ESS Outlet" "Energy Storage System Outlet Temp" "°C" 0
1568 "Eng Act Trq" "Engine Actual Torque" "Nm" 0
1598 "ECT" "Engine Coolant Temperature" "°C" 0
1599 "Eng RPM" "Engine Speed" "RPM" 0
1500 "CRFM" "Front End Cooling Fan Spd Cmd(%)" "%" 0
1543 "Htr Vlv Cmd" "Heater Core Coolant Valve Cmd" "%" 0
1609 "Htr Vlv Pos" "Heater Core Coolant Valve Position" "" 0
1551 "Htr Vlv Pos" "Heater Core Coolant Valve Position (%)" "%" 0
1523 "HV Temp" "High Voltage Battery Average Temp" "°C" 0
1524 "HV Crnt" "High Voltage Battery Current" "A" 0
1504 "HV Cap" "High Voltage Battery Estimated Capacity" "A-Hr" 0
1520 "LT ChrgPow" "High Voltage Battery Long Term Charge Power" "kW" 0
1519 "LT DschrgPow" "High Voltage Battery Long Term Discharge Power" "kW" 0
1517 "HV Max Vlts" "High Voltage Battery Max Cell Voltage" "V" 0
1521 "HV Max Temp" "High Voltage Battery Max Temp" "°C" 0
1516 "HV Min Vlts" "High Voltage Battery Min Cell Voltage" "V" 0
1522 "HV Min Temp" "High Voltage Battery Min Temp" "°C" 0
1542 "HV SOC" "High Voltage Battery State of Charge (VICM)" "%" 0
1550 "HV SOC Gauge" "High Voltage Battery State of Charge Gauge Position" "%" 0
1518 "HV Volts" "High Voltage Battery Voltage" "V" 0
1606 "HV Faults" "High Voltage System Fault Status" "" 0
1612 "Hood Sw" "Hood Switch Position" "" 0
1503 "Aux Fan Cmd" "Hybrid Auxiliary Fan Cmd" "%" 0
1513 "Aux Fan Spd" "Hybrid Auxiliary Fan Spd (%)" "%" 0
1502 "Aux Fan Spd" "Hybrid Auxiliary Fan Spd (RPM)" "RPM" 0
1576 "HV Crnt" "Hybrid Battery Discharge Current (HCP)" "A" 0
1577 "HV Max Temp" "Hybrid Battery Max Temp (HCP)" "°C" 0
1578 "HV Min Temp" "Hybrid Battery Min Temp (HCP)" "°C" 0
1575 "HV SOC" "Hybrid Battery State of Charge (HCP)" "%" 0
1602 "IAT" "Intake Air Temperature" "°C" 0
1605 "MAP" "Intake Manifold Vacuum Pressure" "kPa" 0
1615 "MtrA State" "Motor A Inverter State" "" 0
1592 "MtrA Spd" "Motor A Speed" "RPM" 0
1595 "MtrA Temp" "Motor A Temp" "°C" 0
1589 "MtrA Tq" "Motor A Torque" "Nm" 0
1588 "MtrA Tq Cmd" "Motor A Torque Cmd" "Nm" 0
1616 "MtrB State" "Motor B Inverter State" "" 0
1593 "MtrB Spd" "Motor B Speed" "RPM" 0
1596 "MtrB Temp" "Motor B Temp" "°C" 0
1591 "MtrB Tq" "Motor B Torque" "Nm" 0
1590 "MtrB Tq Cmd" "Motor B Torque Cmd" "Nm" 0
1561 "NumWrmUpsCC" "Number of Warm Ups Since Code Clear" "Cnt" 0
1530 "OBCM AC Crnt" "On Board Charger AC Input Current" "A" 0
1529 "OBCM AC Vlts" "On Board Charger AC Input Voltage" "V" 0
1532 "OBCM HV Crnt" "On Board Charger High Voltage Output Current" "A" 0
1536 "OBCM HV Pow" "On Board Charger High Voltage Output Power" "kW" 0
1531 "OBCM HV Vlts" "On Board Charger High Voltage Output Voltage" "V" 0
1534 "OBCM LV Crnt" "On Board Charger Low Voltage Output Current" "A" 0
1537 "OBCM LV Pow" "On Board Charger Low Voltage Output Power" "kW" 0
1533 "OBCM LV Vlts" "On Board Charger Low Voltage Output Voltage" "V" 0
1535 "OBCM Temp" "On Board Charger Temperature" "°C" 0
1545 "OAT" "Outside Air Temperature" "°C" 0
1546 "Filterd OAT" "Outside Air Temperature Filtered" "°C" 0
1501 "PECL Temp" "Power Electronics Coolant Loop Temp" "°C" 0
1525 "PE Pmp Cmd" "Power Electronics Coolant Pump Cmd" "%" 0
1514 "PE Pmp" "Power Electronics Coolant Pump Spd (%)" "%" 0
1526 "PE Pmp Spd" "Power Electronics Coolant Pump Spd (RPM)" "RPM" 0
1582 "Regen Tq" "Regen Braking Axle Torque (Estimated)" "Nm" 0
1579 "Regen Tq Req" "Regen Braking Axle Torque Req" "Nm" 0
1601 "Sprk Adv" "Spark Advance" "°" 0
1614 "Sys Pwr Md" "System Power Mode" "" 0
1538 "AC Energy" "Total AC Energy Used Durning Last Charge" "kW-hr" 0
1540 "HV Energy" "Total HV Energy Used Durning Last Charge" "kW-Hr" 0
1539 "LV Energy" "Total LV Energy Used Durning Last Charge" "kW-Hr" 0
1566 "Trans OutSpd" "Tranmission Output Speed" "RPM" 0
1555 "C1 Slip" "Transmission C1 Clutch Slip" "RPM" 0
1556 "C2 Slip" "Transmission C2 Clutch Slip" "RPM" 0
1557 "C3 Slip" "Transmission C3 Clutch Slip" "RPM" 0
1558 "C4 Slip" "Transmission C4 Clutch Slip" "RPM" 0
1559 "C5 Slip" "Transmission C5 Clutch Slip" "RPM" 0
1613 "Trans Md" "Transmission Mode (Hybrid)" "" 0
1565 "Trans Temp" "Transmission Oil Temp" "°C" 0
1567 "Trans Ratio" "Transmission Ratio" "" 0
1600 "Veh Spd" "Vehicle Speed" "Km/Hr" 0
Hope that helps!
Gordo
So when we've heard in the past that the Volt doesn't have a OBD-II term for instantaneous kW power usage, if this list is canonical that's true. There's no "HV Pow" term.
But (if one were to have described the ordinals in a loose BNF form), it should be no more difficult than <1524> * <1528>
This looks... Interesting. Does term <1613> return modes as described in the patent? And I don't see an obvious way to tell if the friction brakes are deployed...
Discussion Starter #14
Trans Mode (1613) is just the selected shifter (P,R,N,D,L) position. As for the friction brakes, I haven't found the correct input for that yet. Most inputs are pretty clear but I am still trying all the different inputs to make sense of a few of them. I did suggest to the people at Drew Tech that they compile a list to describe each signal (their description) input.
This is extremely interesting indeed. It seems I have some OBD protocol reading up to do.
Is there any other functionality in this device beyond pulling the codes, storing and displaying them? Because if that is all it does, I would assume raw data acquisition with a less sophisticated device and offline analysis with a PC is possible as well. $700 is a good deal of money for something that I have no rational justification for - except loving statistics :)
JetJock, were you able to get a display of kW consumption/generation going? I spoke with them yesterday, and after hearing that you can do a sensor*sensor calculation for a display looked it up in the owners manual. It does, in fact, look pretty easy in theory...
I'm seriously considering one of these pups so I can get answers to the "Just what does driving like X do to Y" type of questions...
I did ask about the second OBD-II connector in the car, and they muttered about how it's proprietary and may not even be OBD-II signaling/voltages - and how that might damage the DashDaq if I tried to plug it in... I'm somehow dubious of that, but I don't think I'm keen on risking that expensive a unit just to try it out.
Does the maintenance manual have anything to say about signalling and what data's available on the passenger side OBD port?
Hey JetJock, did you ever come up with any skins you like?
I've been trying things out with mine today, and I have a skin (actually, just a one page skin) that displays:
Motor A RPMs (analog gauge)
Motor B RPMs (analog gauge)
Engine RPMs (analog gauge)
Transmission output RPMs (analog gauge)
Motor A Torque (analog gauge)
Motor B Torque (analog gauge)
Engine Torque (analog gauge)
Axel Torque (analog gauge)
Motor A kWh usage (analog gauge)
Motor B kWh usage (analog gauge)
Battery kWh usage (analog gauge)
Driver Requested Brake Torque (analog gauge)
Regeneration Brake Torque (analog gauge)
4 X medium sized Digital Gauges (which I'm just poking stuff into, while I flesh the thing out).
The Brake Torque gauges are more interesting than I expected. Presumably anytime the regeneration torque is less than the requested torque the mechanical pads are applied. During relatively brisk braking it's interesting to watch the regeneration trail the driver's requests, and how quickly it catches back up.
The ddskin file is about 800 kB. If you're interested I can try to send it your way, but I don't know that I can post it to the forum or as a PM. It gzip-s down to about 68 kB though, so maybe if I compress it. My firmware revision is different from yours though (...-2036), and some of the signals are different. Doesn't look like any of the ones I'm using though...
Discussion Starter #19 (Edited)
Motor A RPMs (analog gauge)...
That is really interesting, thanks for the info!
As for the skins....I am in the middle of a divorce and don't have much free time to mess with it. Hopefully I can get to it in the next few months. I love the device and fine tuning the gauges would be really helpful.
Also, the input list I posted was sent to me by the DashDaq people. My firmware is the same as yours.
Gordo
1 - 20 of 95 Posts
