1 - 9 of 9 Posts
(My first post at GM-Volt.) Bought a 2013 Volt certified from a Chevy dealer with 27k miles in March. First GM vehicle I've owned. I love this car!
I decided to paint the lower edges of the doors to match the dark gray plastic rocker panels and to correct what looks to me to be a styling mistake (a cheap shortcut).
Bought some flat black and flat white Rustoleum paint,
mixed them in a jar to approximate the dark gray of the plastic (tested by painting a small patch and waiting until dry),
masked the line (easy- tacked one end, pulled taut to other end, then tacked along the way),
and painted it with a small brush. It all took less than an hour.
Cheap, quick, easy; I think it’s an improvement. The lines now “make sense” to me, and I think it makes the car look longer and lower. I think I even like this better than the body-colored Ampera look.
Hopefully the paint will hold up; I’ll let you know in five years or so!
Interesting! Now you have me thinking of doing this to my 2013 red Volt.
Carlysle
Interesting approach.
How did you prep the painted door surface prior to painting?
Discussion Starter · #5 ·
Surface prep was just washing it. Rustoleum sticks to a variety of surfaces and is fairly durable. I considered a light sanding of the surface, but I decided not to so that I could reverse it if the experiment didn't work. If my results are still satisfactory after a year or so, I would recommend light sanding if anybody else tries it.
Good Luck :)
So, another reason why I bought a black car...
I just used black wax on the grey plastic. Held up for a few years, might be time to reapply.
Discussion Starter · #9 ·
Update: after 19 months, the paint still looks good to me; no bubbles, peeling, or even fading.
1 - 9 of 9 Posts
