1 - 6 of 6 Posts
Does anyone happen to know if 208 VAC 2-phase charging is supported on the Volt, rather than 240 VAC bi-phase? Just curious if this is specified either on the Volt, or perhaps with the J1772 standard.
I believe all Volts can charge off 208 volt power, but the charging rate will be reduced by about 10%, due to the lower voltage.
Good to know - thanks! It just occurred to me that *my* work chargers may also be running off of 208 V, but I don't know how they're wired.
A commercial building has a WYE transformer for it's 120vac 1ph power. It has 4 wires going out:
L1 - Hot 120v
L2 - Hot 120v
L3 - Hot 120v
White - Neutral for 120v
Any two of the L1, L2, or L3 lines when hooked to power leads makes 208vac, not 120v. Why? They are 120° separation. Only when they run a 3 phase motor do they kick out 240v.
You do not use the Neutral on a 208 circuit. You would use a second Hot instead.
L1 - Hot 120v
L2 - Hot 120v
L3 - Hot 120v
120/208 "wye" is the current "standard" way of getting 3 phase and 120 volts 1 phase out of a single service, but there are also lot of 120/240 "high-leg delta" 3 phase systems out there which work differently.
https://en.wikipedia.org/wiki/High-leg_delta
1 - 6 of 6 Posts
