The Volt designers have probably already thought of this method of improving fuel economy in RE mode.
The ICE has a peak efficiency point vs. load. If typical crusing power consumption is significantly below this peak efficiency point, then it would be more efficient to cycle the engine on and off. If the battery starts at 80% SOC, and drains to 35%, then the ICE would kick in and charge (at the peak efficiency point) to 40% and turn off, until the battery again drains to 35%. If the battery SOC ever gets to 30%, then the ICE would go to full power until the SOC is back to 35%, at which point it would throttle back down to the peak efficiency point. If two throttle settings are not enough, then another level could be added at 32.5%
So in summary,
1) The ICE would never be operated below its peak efficiency point vs. load.
2) Only under extreme driving conditions would it need to operate above the peak efficiency point.
In my experience, this mode of control is much simpler (and therefore better) than trying to develop a closed loop controller that maintains SOC. If a simple rectifier is used, then its nonlinearity renders linear control textbooks useless, whereas this hysteric control method always works.
So in summary,
