My lease is up on my 2015 Volt in four months. I had a 2013 before the 2015, so they were both first generation Volts. I am not familiar with Gen 2 Volts. Are there any pros and cons out there regarding a 2018 Volt. All comments much appreciated.
This is exactly what I felt when cross shopping gen 1's with a new gen 2. I'll also add the gen 2's feel much faster off the line than a gen 1, up to maybe ~30-35 mph.I just turned in my Crystal Red 2015 lease. It was my second Gen 1 Volt. I leased a 2018 LT, with comfort package, leather and driver confidence package. That was my minimum configuration and I'm happy with it.
Now that I've owned if a few weeks, I'd say I agree with everyone below on its attributes over Gen 1. But for me, I'm just more at ease driving the newer car.
It's more fling-able in corners - less top heavy. I no longer have to think about braking, the new system is far more intuitive, and linear feeling. The handling is very neutral and safe, where the original car seemed to understeer more. The ride is far better with impacts being muted much better. Almost NO wind noise, unlike Gen 1. Far less sharp impacts are transmitted to the driver from the road. And finally, the steering is far more precise. Add it up and the new car is just easier and more relaxing to drive and the range increase is just what we needed. Do it!!
Sorry about this. I think my original post was poorly worded. I definitely think the Gen 2 ICE is a lot more refined than the Gen 1. I was mostly praising how the engine rarely kicks on "randomly" when at empty battery and operates/sounds more like a normal quiet modern 4-cylinder when matching your right foot, rather than coming on to recharge the battery when your stopped at a stoplight, which can be disconcerting if you don't know why it's happening.However, I drove my 2013 Gen 1 on ICE a lot and, unlike Jonesy's experience, my 2017 Gen 2 is more unrefined overall on ICE than my Gen 1. The Gen 2 is quieter than Gen 1--unless your Gen 2 has the "backfire" (technically an "afterfire") issue.
The visibility out the rear is a little limited, but not much worse than a Gen 1, and for parking purposes, you're aided by a great backup camera standard on all models. The B-pillars are pretty thick too, but I haven't found them to be a real problem as long as my mirrors are properly aligned. Generally it's about the same visibility all around as a Gen 1, and a little worse out back, but nothing that should sway your mind on a purchase decision.Thanks for all the helpful comments. With the redesign on Gen 2 has anyone noticed any visibility issues?
Especially if you get the cross-traffic alerts (for backing up) and the blind spot alerts...worth their weight in gold IMHO.Generally it's about the same visibility all around as a Gen 1, and a little worse out back, but nothing that should sway your mind on a purchase decision.
The backup camera with rear cross traffic alerts and park assist sensors make backing up super easy.The visibility out the rear is a little limited, but not much worse than a Gen 1, and for parking purposes, you're aided by a great backup camera standard on all models. The B-pillars are pretty thick too, but I haven't found them to be a real problem as long as my mirrors are properly aligned. Generally it's about the same visibility all around as a Gen 1, and a little worse out back, but nothing that should sway your mind on a purchase decision.
I miss the lower back window in the hatch area in the Gen 1, but got used to the Gen 2 very quickly--like with all cars after I've driven them for a while. I also have the cross traffic alert (sometimes helpful, but often overly-sensitive), and all other safety packages, which (in my opinion) are absolutely worth it. At the minimum, get the blind spot monitoring which I find VERY helpful.Thanks for all the helpful comments. With the redesign on Gen 2 has anyone noticed any visibility issues?
