I completely agree. No way would I charge at home with this situation. Use that gas card and feel good about it.Nope. If your company is too short sighted and stuck in their ways, let them pay.
Great point. Is there a cost per mile figure on running the ICE, excluding gas and tires? I guess that's service (oil, preventative maintenance, spark plugs, brakes) ?I would spend my couple of bucks per day to charge the vehicle (and also do what MTN Ranger suggested if I was in USA).
Correct me if I am wrong, but if I understand many of the articles discussing TCO that I have read, running as much on the electric motor as possible (and using regen braking) is one way to minimise wear and tear on the ICE portion of the vehicle and therefore keep traditional servicing costs down (especially brake pad replacement and oil change costs). There will still be those costs, but likely less frequently.
I have a different approach than RePo on this one. If I were broke, then I would charge the gas card, but if I made any sort of decent living, I'd pay for my own electricity since it (1) isn't that much (2) might be beneficial to the environment {it all depends on how the power is generated} and 3, at least with a Gen1, the smoothness of all EV outweighs the attempt to save a few bucks and dealing with the ICE causing noise, vibration, and harshness.I like the approach RaPo takes. Perhaps this will lead to a change in thinking that is certainly due.
It's kind of like Tramadol. Once you had some, you never go back to aspirin.I've seen the opinion expressed that, after a while, Volt owners would grow tired of plugging in and just start using gas. That's not even remotely true. Running on battery is strongly preferred. Judging by the poll results so far, it seems it's preferred even when the gas is free.
