So I am getting ready to leave work last night. The temp was 6*C (42*F). Now my boss has been pretty good and has put in a 120V outlet for me. I am still working on the 240V, but I digress. So I live 66 km (41 miles) away from work, and can get to work on a single charge, but the 8 hours I am plugged in is not enough for a full charge to return. So anyway, I get in my Volt and it says I have 44 km (27 miles) of EV range. I set the Nav for the return home ( I know how to find my way, I just like the traffic advisories on route!), and it says, no surprise 66 km. Now if I had a hold button, I would have started the engine right away to get the heat from the engine to help warm the car, thereby increasing my range. Mountain Mode won't work soon enough with the level of charge I started out with. Wouldn't it make sense to have the ability to start the engine at the beginning of my trip for the heat than at the end when the car is already warm?
Or even better. The car knows how much range I have, the car knows the outside temp, the car even knows how far I will be travelling through the NAV, so Chevy engineers why not add a line or two of code that allow the volt to say "Hey, I know he doesn't have enough EV range, and I know he wants to be warm because he set his climate controls, and I know that I am going to have to run the ICE sooner or later, why not now?" There must be an optimum RPM for the ICE with respect to electrical generation. Maybe it would be better to have an option to select a constant low engine speed to generate electricity for only the amount of time necessary. If you are travelling 200 km (120 miles) or so, the engine could maybe idle for a while to generate enough power. Now I know that arriving home with electrons aboard generated by gas is a waste, but they should be able to get pretty close. All the information is already in the Volt, someone just has to connect the dots!
