starting to see some cold weather -17 c or 1 deg f with the 2016 car,
first off , I have to apologize to all the tree huggers out there, seems like I'm all about saving the planet until my butt gets cold, then its, come on global warming!
our area will hit -30 in either temp in jan-feb , so that is yet to come, I'm wondering how the car will handle those temps
when the temp hit 0 c /32 f with a skiff of snow, I almost put it into a curb, the high mileage hard rubber tires don't work on ice or snow, so off to the tire shop and a set of Michelin ice tires put on
these tires are very soft ,in high temps they will wear very quickly , so only run when cold, being soft , they really take the stiff ride out of the car, and kill the range ,but will keep you on the road on snow or ice.
I also found out these tires will handle on snow and ice, hard braking or regen in low ,but will not handle regen paddle, I think gm should reduce paddle regen at about -3 c by about 20 %,a few times it got scary to the point of me refusing to use it at that temp.
moving forward to -17c , command start starts the engine, the range is down to 45 km on battery, and I find me putting it straight to hold to get the engine up to 80c as fast as possible to heat the cab, the electric seems to maintain the heat fine but seems to struggle to warm it up quickly
the only problem with this is every time you slow below 50 km the motor shuts off, and I find my self going nooooo, so it takes way longer to get the motor up to temp then it could
I think the car needs a cold weather mode, if the cab can use the engine coolant it would be nice to first heat the engine up and then go hybrid -10c and lower
did I mention its an awesome car
