1 - 4 of 4 Posts
Hello
The above code went away after a day. I have heard of others have this happen and I do not think it is abig deal. ???
The Volt is a bit sick. A search of the above code says its a ABS pressure pump problem, but the onStar people called it something else. She said transmission and charging, which does not even address ABS or brakes and that I have 7 days? Maybe she read the wrong code. And I called twice.
The car did not start and had a 'service stablity track message". Turn car off and on and she starts. The Volt is usually a she? Check eng icon still on, but seems fine today except for the light
In either case I guess I will have to go to the dealer. The last time they said they do not always have to give you a loaner. But they always do, if they keep it overnight. If just for the day they use the cutomer van and guve you a ride to work.
OH well. I hope its only a bit sick.
The dealer no longer pays for rental if car kept overnight with warranty work. Even though GM will pay them. Is there a way to get GM to pay for a rental without going thru the dealer? Probally not.
Tim S
2015 Volt
Strange code, there is a bulletin that explains this may be a brake issue or a engine computer issue.
If the vehicle has a current or history DTC: C012E symptom code 00 in the EBCM and a C12FE in the ECM, the vehicle has a brake issue. The technician needs to follow SI for DTC:C012E which has you perform a hydraulic test and a pedal travel test to assist in finding a brake issue
 2. If the vehicle has a current or history DTC: C012E symptom code 12 without a C012E symptom code 00 in the EBCM and a C12FE in the ECM, the code sets due to a powertrain code or a power down issue with the vehicle, this is not related to the brakes. Advise the technician to diagnose other DTCs or issues with the vehicle first.
Hello and thanks I can take this to the dealer tomorrow and pretend i know something
Hello The code went away. I am probally going to cancel the dealer Appt.
I think it has to do with plugging in for just 1/2 hour. I think this has happened to others, if I recall correctly.
1 - 4 of 4 Posts
