I opened my LCS-20 so the mod folks can see what the 20A 240 VAC model looks like.
First, the Relay has a 240 VAC coil (compared with 120 VAC for the stock L1 EVSE that comes with the 2014 Volt). It is from the same Potter & Brumfield series as the relay in the stock L1 EVSE and has the same contact ratings.
Also, as expected, the low voltage power supply jumpers are configured with the labels LCS showing with one jumper in the middle (see my previous posts about the L1 stock EVSE for an extensive discussion of this jumper setting; posts #32 to #34. These jumper configure the two primary windings of the Triad low voltage linear power supply. The low voltage linear power supply is not a switching power supply and does not do any auto-configuration. The input voltage range is limited and applying 240 VAC to a 120 VAC configured transformer primary (parallel connection) will damage or destroy both the small transformer and likely the regulators (double the power supply designed voltage out of the secondary).
Although the "builds" are very different, note that the PCB number is the same. Also, the labels at the end of the board are very different from the sock L1 EVSE (see prior posts). The L1 stock EVSE board says PCBA "C", the LCS-20 L2 says PCBA "A".
The original mod (not the adapters that power an un-modded L1 EVSE at 240 VAC), is closer to "okay" than I initially realized. See the updated comments in the thread above.
This confirms expectations from the views of the jumpers and relay in the L1 EVSE. The ClipperCreek L1 EVSE and L2 EVSE are NOT the same and applying 240 VAC to an un-modded L1 EVSE will cause premature failure ranging from an open relay coil (plays dead) to smoke and fire. It is a credit to ClipperCreek's relatively conservative design that those who claim the un-modded L1 EVSE is the same and can be powered as a L2 EVSE at 240 VAC, so far have not reported smoke and snapping sounds (or fire).
