Hello, been an off/on reader for awhile now, and a few months ago bought a CPO 2013 Volt I believe with everything except stand alone navigation. Cyber gray with chrome wheels.
Anyway, it was still relatively warmer weather when I bought mine, and now that I have had it through some colder weather, I have been rather disappointed at the heater/climate control system.
I have had it in for service for no/little heat while on electric, and while they said it was working as intended, the did do something because now the does work on electric, but not what I consider adequate.
I have, over a period of time, tried to read through the many threads regarding the heater/controller issues, but as stated the service dept found nothing wrong.
Heat while ICE is running, is mostly OK.
Given that introduction and background info, the point of this thread/poll is to determine the, for lack of better terms, quality/consistency of climate control (winter) the system provides, in order to help myself and other users determine if their climate control is functioning 'as designed' or not so much.
This is in regards to gen 1 Volts, and these questions/answers are requesting *measured with some kind of thermometer* cabin temp, not 'guestimated' or how it 'feels' or whether it is comfortable.
I use an lcd temp/humidity gauge velcro'd to my dash, near a vent but vent not blowing directly on it.
Also you can assume that comfort mode is used.
Outside temp, as displayed on panel 30 to 50F.
I am trying to gather some factual data.
questions:
1) My Volt climate keeps the cabin air temperature (not vent temp) perfectly at the same temp as set on the climate temp?
a) yes, my measured cabin air temp closely tracks the temperature that I have set on the climate control.
b) mostly, my cabin air temp is normally within a few degrees of the climate temp.
c) not really, my cabin air temp is normally 10+ degrees lower than the set climate temp.
2) It generally takes how much time for your Volt cabin air temp to reach your set comfort temp? (obviously a lot of factors can affect this, but as in general when you leave for work in the morning etc)
a) I use pre-conditioning and my cabin air temp is normally reaching comfort set temp immediately or within 5 minutes.
b) I don't use, or when I don't use pre-conditioning, my cabin air temp warms up within 5 minutes or so (with or without ICE heat assist).
c) My cabin air temp typically takes about 10 minutes to get where I am comfortable or to specified temp.
d) My cabin air temp typically takes longer than 20 minutes to get comfortable or to specified temp.
3) With electric only heat:
a) my electric only heat warms up fast (1-3 minutes) and keeps the cabin air temp at or near specified temp.
b) my electric only heat takes a few (~5-7) minutes and will bring cabin temp up to or near specified temp.
c) my electric only heat takes a seemingly long time (10+ minutes) to bring cabin air temp up to or near specified temp, or never reaches specified temp (within the ~30 mile electric range).
I probably have a few more questions to add later but these are the biggies I'd like to get out there.
I'll post my own personal answers in a later post.
questions:
