1 - 1 of 1 Posts
Have a noise coming from what I think is the transmission. I tightened the axle nut to 185 ft/lbs (it was not loose) and checked out the brakes (see picture).
While doing the above I noticed there was a good bit of play in the Axle as it went into the trans. Note that car was jacked up and in Park. When I turned the axle back and forth by hand I could hear the thunking noise.
Any ideas if this is the problem, if so how dangerous is it and would it be covered under the 100,000 part of the warranty?
Thanks
1 - 1 of 1 Posts
