1 - 4 of 4 Posts
I have adjusted the Chime volume setting several times, off, low, mid, and high but the volume of the chime when I start the car without having seat belt on is always quite loud. What does the chime volume adjust?
MY 2017 Volt.
Thanks,
Tim.
On our 2017 it works but you can't shut it off. IMO minimum is loud and maximum is painfully loud. Must be a safety feature!
There is also an audio cue control for the startup/shutdown swoosh. It can be set to off.
There is also audio auto level which can be set to increase the volume based on speed and background noise and a audio start volume which will return the volume to a preset lower level than the last trip.
Finally there is a audio maximum volume setting as part of the "teen driver" settings.
1 - 4 of 4 Posts
