2013 Volt - ~6k miles - Standard 120v charger
So as the title says, I've received these codes from onstar. Running the remote diags have come back with them and the onstar rep told me if the car wasn't having issues charging, then there would be no need to service and the light would go away. That was true and after a couple of complete charging cycles, the light did go away.
However, this has happened now 4 times. Each time, I've noticed that this has happened when my volt has been plugged in for an extended period of time, sometimes for a few days without being run.
The charger is plugged into a circuit in my garage. There are a few other things plugged into it, but nothing really heavy. I think there is a small 12v battery backup for my fiber internet and a charger for our swiffer vacuum. When I charge, I always change it to 12a otherwise it won't completely charge over the night. I've never had the breaker trip on me either, so I don't think any of the other devices are messing with the volt charger, although I'm not totally sure about that.
Every time this has happened, it will clear in a few days. So I'm curious if this might be an issue with the charger? Also, it has been a very cold winter here, sometimes getting close to 0, and when this happens, it always happens over night, never during the day if I plug in. So I wonder if the garage gets really cold if that could be hindering something, but surely not.
I'm going to schedule a service appt with the dealer, but I was curious if anyone had any input on these codes or issues before I did that. There is nothing apparent that I can tell is wrong with the car and I'd rather not have to go into the dealer and be without the car for a couple days if I can avoid it. Any suggestions would be welcome.
