2012 Volt - Check Engine Light and Propulsion Power is Reduced
For about the sixth or seventh time in the past year, charging was interrupted and the check engine light appeared in our 2012 Volt. On the drive home, my wife connected to OnStar and they advised of two error codes: P1E98 - High voltage system is not functioning properly (bring in within one day) and P1E00 - Charging system is not functioning properly (bring in at earliest convenience). In the past when we've had these error codes, it cleared up after 2-3 charging cycles. I was fine doing this "remedy" again until something strange happened. My wife plugged in the car when she got home and everything seemed okay for a bit. Then, the charge got interrupted and re-started about 6-7 times in an hour. When we went to the car to go out, the charging light was dark (no yellow, no green, no flashing green). I unplugged, got in the car and the information center displayed "unable to charge". When I started the car, the gasoline engine came on immediately and the information center now displayed "propulsion power is reduced". I turned off the car, re-plugged in and everything appeared to be functioning as expected (charging light turned to solid green). However, when we started the car, the CEL was still on (as expected).
After all this, I immediately drove the car to the dealer and explained the sequence of events. They won't be able to look at it until Monday (as well as taking care of the service bulletin for the power inverter module reprogram). So, now we play the waiting game...again (about the 5th time my Volt has been in the shop in less than two years).
I want to get this resolved (hopefully once and for all) because I am driving my Volt from Orange County, CA to Chicago in a few weeks.
Any insights or comments are welcomed!
