A gen1 volt needs about a 4,000 watt system to reliably run a 240 volt charger, or a 1,500 watt one to run a 120 volt charger. Each panel puts out roughly 240 watts with maximum sunshine, so you will need about 18 panels for the 240 volt system, or 7 panels for the 120 volt system.
I just purchased panels for $100 each , including shipping and tax. You can get a 3,000 watt continuous duty inverter for about $300, which would be enough to handle the 120 volt system, and cost about $1,000 total, but you would also need a battery system to stabilize the voltage, plus another few hundred for the mounting hardware and another few hundred for the special 12 gauge wires and special connectors that are used for solar.
So, even that 120 volt system would cost nearly $2,000 in parts, and the 240 volt one would probably run close to $4,500.
I am not trying to discourage you, just want you to have a realistic idea of the cost and work required for a system that would handle it.
