The charging plug will not disengage from the charging socket. 2011 Chevy Volt
Don't force it. If charging has been completed you can safely unplug the EVSE, else turn off the power at the breaker. If needed, you can disassemble the J1772 connector handle to access the release.The charging plug will not disengage from the charging socket. 2011 Chevy Volt
