Good point!True but the Volt only uses 65% of the battery so we are talking .65Kwh which should be around an extra 40 minutes.
Actually, the additional capacity is all in the usable part of the battery based on the way they adjusted the various SoC limits.True but the Volt only uses 65% of the battery so we are talking .65Kwh which should be around an extra 40 minutes.
They changed the amount of usable battery range to 65% in 2013 I believe. I got 10.8-10.9 most of the time when i use to fully deplete my battery.I usually got around 9.6 kwh of battery on my 2012, according to the center display, which was only 60%
This is what I would say as well. The OP likely has the car charging at 8 amps rather than 12. Hence the longer time. The 2012 would also take 12 hours is charged at 8 A, but that car has the default at 12 vs. the newer car's default of 8.the answer can be found in the new 8 amp default charge rate I believe.
I looked at the Chevy.com site. You are correct.An 8 amp charge should take something more like 16 hours. The OP is likely seeing the effects of the larger upgraded battery found in the 2015's, combined possibly with battery thermal conditioning during the recent colder weather.
Using a 120-volt standard outlet will take approximately 10 hours to charge your Volt at the
12 amp setting, or 16 hours at the 8 amp default setting. Using a 240-volt charging station
will take approximately 4 hours. Charge times will vary with outside temperature.
I'd go with this. The battery has 7% more capacity. If more of the battery is being used the charging rate may also be dialed down more towards the end. Add in temperature and it would be fairly easy to increase the charging time by 20%.An 8 amp charge should take something more like 16 hours. The OP is likely seeing the effects of the larger upgraded battery found in the 2015's, combined possibly with battery thermal conditioning during the recent colder weather.
