I'm going to sya that it seems alot of us are having the same run of bad luck!
I'm going to say the opposite, a handful have had issues and many of those where the result of not taking precautions.
120V charging guide:
http://gm-volt.com/forum/showthread.php?48937-120V-Charging-FAQ
Owners Manual:
WARNING Using the charge cord with a worn or damaged AC outlet may cause burns or start a fire. Periodically, check the AC wall plug and charge cord while the vehicle is charging.
If the AC wall plug feels hot, unplug the charge cord and have the AC outlet replaced by a qualified electrician. Replace the charge cord if the AC wall plug or cord are damaged. Do not use an AC outlet that is worn or damaged.
Electrical Requirements for Battery Charging
The AC outlet must have a
grounded, dedicated, 15 amp or
greater, three‐prong wall plug.
That means there should be no
other major appliances connected
to the same circuit. If it is not a
dedicated circuit, the current rating
of the outlet circuit breaker could
be exceeded and cause it to trip
or open. The vehicle can be
charged in the reduced level mode.
See “Charge Level Button” in this
section. Reduced level mode allows
a non‐dedicated circuit to be used
but increases the charging time.
This vehicle is capable of being
charged with a variety of standard
vehicle charging equipment.
The following are the minimum
requirements for circuits used to
charge this vehicle:
120V/15Amp
240V/20Amp
