Before anyone goes "spray some silicone on the gasket/seal and latch pin, thus is NOT my problem as of right now. I've done that prior to correct the sticky door.
My car is an early '11 model. Suddenly the other day, the charge door would not open. I assumed it was just sticking, like the other thousand posts on the forums have been about. The difference I'm seeing (or actually hearing) is that I hear the relay from the underhood fuse center click when I hit the button on the key fob, or on the door panel. I DO NOT hear the solenoid/actuator activating when i push the buttons. Have I lost the actuator?? Is there a manual way to get the charge door open??
Diller
'11 Volt Premium
Sent from my SAMSUNG-SM-G935A using Tapatalk
Diller
'11 Volt Premium
