Try doing a remote conditioning while still plugged, an hour before you jump in the car. It could increase your range to near 53 even if the weather is colder.Level e 2 charger. Charge light solid green, range is at 43 miles instead of 53 as I would expect is it the charger or the car?
Those range numbers are mere estimates and are not a reflection of a fully charged battery or not.Level e 2 charger. Charge light solid green, range is at 43 miles instead of 53 as I would expect is it the charger or the car?
If your charge light is truly SOLID green, you have not completed the charge yet. Of course it would not read your full mileage.Level e 2 charger. Charge light solid green, range is at 43 miles instead of 53 as I would expect is it the charger or the car?
If they are on a 2017 IIRC it is flipped from the Gen 1 volts. Sold green means it has finished and flashing means charging.If your charge light is truly SOLID green, you have not completed the charge yet. Of course it would not read your full mileage.
Dick
This gets me sometimes. I have a gen1 and my wife has a gen2. One blinks and one flashes all the time!If they are on a 2017 IIRC it is flipped from the Gen 1 volts. Sold green means it has finished and flashing means charging.
