1 - 3 of 3 Posts
Hi! I have connected my cell phone to the car via bluetooth. However, for some reason, my phone does not ring thru the cars speaker system. I have looked thru the owner manual and have not found the answer.
I will see the person's name who is calling, however, it does not stay on the display long nor do I hear it ringing.
Any ideas?
Thanks in advance!
Not sure but I wonder if you have your cellphone muted for calls whether that would be the same in the vehicle via bluetooth?
I would try this:
While you are in the vehicle (with the vehicle on and your phone bluetooth-connected), have someone nearby (a friend or family member) call you. While your phone is ringing (even though you can't hear it) try turning up the volume in the car either with the dial or the buttons on the steering wheel. Some volume settings in the car can only be changed while that particular audio source is actively delivering a signal and it could be that your bluetooth phone is currently set very low (0).
1 - 3 of 3 Posts
