Now that the cold season is here and the range of EV's are getting shorter, what are the causes?
1. The battery pack could not take in more charge? If so, what would be the available kWH per full charge at low temperature, take 40F as an example.
2. Does it consume the same amount of energy from the wall for a full charge? What is the energy spent to keep batteries at optimum temperature while plugged in, let's say at 40F?
3. Does GM's algorithm play with the actual state of charge values so that the car can buffer or attenuate the effect of temperature?
4. Does the car consume more power to move it when the ambient temperature is lower? Assuming you're not spending any energy for cabin climate controls. I've noticed that it requires more kW power to maintain the car at 60 mph when temperature is lower.
5. other factors related to temperature?
I've used data from various Volt owners and analyzed them, but forgot to take data from the actual kWh used.
VoltTemp by Joe Real, on Flickr
