I do! I just got mine a day or two ago from the dealership, since the original owner didn't have it, and I made them sign docs agreeing to provide one before I'd put pen to paper anywhere else. They came through, and now I just need to figure out a way to charge without the fear of having my EVSE stolen or getting stuck in the mud in the back yard. Incidentally, I'm also trying to figure out DIY gravel parking pad construction. Apparently it's easy-ish to do, but easy to get wrong, too.I've been using the one that came with the car for all at home charging. Do you have yours?
What did they give you? It may be moddable for L2 charging.I do! I just got mine a day or two ago from the dealership, since the original owner didn't have it, and I made them sign docs agreeing to provide one before I'd put pen to paper anywhere else. They came through, and now I just need to figure out a way to charge without the fear of having my EVSE stolen or getting stuck in the mud in the back yard. Incidentally, I'm also trying to figure out DIY gravel parking pad construction. Apparently it's easy-ish to do, but easy to get wrong, too.
My thinking as well. Maybe send pics to ChrisTX and see what it actually is. If it's a 2016 or newer model OEM EVSE, there is no modification necessary to charge at 220v.What did they give you? It may be moddable for L2 charging.
If your EVSE has a handle and has screw holes in the back, it's the proper 2013-early 2014 Voltec EVSE that is OEM from Clipper Creek....
I've been thinking about doing the modification to my OEM EVSE to make it L2, I just need to grab the model number and version info so I know what gen of the equipment I have and whether or not its even necessary.
RE the Voltec l2 mod, are there any issues with watertightness or heating of the cable connected to the J1772 head reported by folks who have had the modification done? I know I'm getting ahead of myself, and it might not even be a point of concern (if I have a cordset that doesn't require modification), but I'm still a little curious.
