1 - 6 of 6 Posts
Preliminary Procedure
Lower the front of the headliner to access the sunshade electrical connector, if necessary. Refer to Headlining Trim Panel Replacement .
1 Visor Retainer Bolt Cover
Sunshade Fastener (Qty: 3)
2 Caution: Refer to Fastener Caution in the Preface section.
3 Sunshade Assembly
Procedure
1. Squeeze the tabs at the base of the sunshade assembly to remove from the headliner.
2. Disconnect the electrical connector.
I don't know if a pdf will post where you can read it but this is apparently the steps to remove the sun visor for replacement.
Discussion Starter #5
Went to the dealer today and asked about the clip of the sun visor. (not the sunvisor itself, just the clip). He told me there is a back cover and I simply need to remove that to see the screw in it. I'll do this once I receive the part and update here.
Discussion Starter #6
There is a small opening on the back of the sunvisor clip, with the screw driver you can open the back cover, which directly expose the screw inside.
Problem solved.
1 - 6 of 6 Posts
