1 - 9 of 9 Posts
Can you charge the Volt by plugging into a modified sine wave inverter?
Or would you need a pure sine wave?
The Volt is picky about power. I doubt it'd like modified sine wave, but I've never heard of anyone trying or considering it. What circumstance would you be in where it'd be desirable to do that?
Check the DCFusor thread about his off grid solar setup, I am pretty sure he is using a MSW inverter.
It will work on a pure sinewave inverter. I have charged from my Outback 3.6 KW pure sinewave inverter with no issues. Have never tried a MSW inverter... Would be scared. :)
I would like the ability to charge the Volt offgrid, but want to keep the cost of the inverter down as much as possible. I suspect I'll need at least a 2000 W inverter as I don't have a large batery bank and will only be charging when there is full sun and fully charged batteries. That way all the power generated from my 3200 W of panels can go toward charging the Volt (assumes ~70% panel to current at battery terminal efficiency).
I would think the bigger issue would be whether or not the Volt charger would error out given the grounding structure of an inverter for the third prong of the outlet.
I did need to tie the N to G on the sine wave inverter to prevent a fault on the EVSE.
Ah, okay. :) Did you do that inside your inverter?
1 - 9 of 9 Posts
