1 - 7 of 7 Posts
So, I found a Honda charger (it's made by Panasonic) at a local swap meet. It was $20, so I bought it. I figure it might be broken, but I can use the parts for when my stock, plastic Chevy charger wears out.
The Honda charger has a much nicer nozzle. More metal parts.
But how can I test this thing? I don't want to plug it into my Volt to test it.
Any suggestions? I have a volt meter and am not afraid to poke around. I think there is an interlock switch or something I have to trigger in order to measure the voltages, right? Also, I think there are contacts or something that have to engage before electricity flows into the car?
Thanks.
As Jay said, if the plug is the same it'll work just fine (assuming of course the Honda unit isn't broken)
  • Like
Reactions: Wayne Y
I use the EVSE that came with my wife's Clarity PHEV in my Volt whenever I travel. You do have to tell your Volt to charge at 12 amps though as the Honda EVSEs don't handle 8 amps very well.
  • Like
Reactions: Wayne Y
Discussion Starter · #5 ·
Thanks all -- yes, the connector / nozzle is the same - I will give it a try when I need to change next. This stay at home stuff is extending my time between charges . . .
Finally had to charge my Volt this morning. And YES - the $20 Honda charger works fine. As mentioned, the Honda unit has a better quality nozzle and cables. More metal parts, heavier gauge wire. Nice price.
171144
171145
2014 Cadillac ELR
Good score! Glad it works. Always nice to have a spare.
1 - 7 of 7 Posts
