1 - 9 of 9 Posts
So in reading the forms I see the gen 2 volt charger can be used with 120/240 however can the last rendition of the gen 1 2013 volt charger?
172996
Yes, with a modification. That one is made by Clipper Creek and the case should be secured with screws. It needs to be opened up and a wire or 2 needs to be moved and soldered. The Lear units with the 4 LED’s are glued shut and need no modifications to run on 240.
Awesome! I just managed to find the video after 45 min trying to search youtube due to the several versions on L1 chargers. Seems simple enough! Thanks for the reply!
Bear in mind that the modified EVSE will have not be able to provide the 16 amps that the on-board charger is capable of handling. The modified EVSE will provide a maximum of 12 amps. Still, it is much faster than charging at 120Volts.
I can confirm the mod works, however, I wouldn't recommend doing it unless you're familiar with how household AC power works and have previous soldering experience.
I also have this version of the charger for my volt 2013. I can not find information about what electronic components are meant to be soldered instead of the factory ones. I have 240V but 50Hz
Is it a United States charger? If it was initially sold in Europe it may be configured differently internally.
Watch this:
1 - 9 of 9 Posts
