Is there anyway to monitor inside cabin temp other than installing a thermometer of some type? I see the outside temp on the center stack, but no inside temp. I did buy a small unit that installs into the power outlet in the dash and it gives me temp, volts and amps draw (if something is plugged into one of the two USB charge ports. But the temp seems to read pretty high which I chalk up to getting some temp from the engine firewall or perhaps from the unit itself when powered up. So then I installed a cheap analog dial thermometer just for comparison, but it picks up the slightest vibration while driving and moves around so much it is hard to read. If I have the temp dial set at 65 does the car automatically try to maintain 65 degrees no matter what mode I have the climate control on??
Doesn't seem to work that way according to my cheap temp monitors.
