Hi guys,
I live in Fairbanks, Alaska. The possibility of owning a Gen 2 Volt intrigues me. I've got some questions for those that have parked their cars outside in extremely cold temperatures. For the purposes of clarity, I define extreme cold as between -25f and -50f.
1. Will the battery be damaged by being left unplugged in extreme cold for up to a week? what about plugged into 120v? If left for three weeks at -40f temperatures and worse, plugged into 120v, is there a certainty that the car will intelligently manage it's electrical limits to avoid battery pack freezeup? Are there warranty limits involved for such cases?
2. Does the engine have a block heater, or is the engine block otherwise warmed while being plugged in? Is 240v required for this?
3. Have you driven successfully in temperatures of -40 without fogging up the windows due to the cabin heating system being unable to keep up?
4. At stationary idle, at what temperature does the cabin heating system reach equilibrium and can no longer thaw the cabin?
5. On starting the vehicle in extreme cold, when it's been plugged into a 240v source, does the generator load up the engine? Is there a way to ensure the battery is depleted enough to make mandatory a charging cycle, even when plugged in beforehand? At -45, most vehicles don't reach operating temperature at idle because the cabin heat takes too much energy away.
6. Does the remote start/precondition result in a warm-ish car in extreme cold events?
7. Does the G2 volt have a coolant-based heater core as well as the electrical heater, or JUST the electrical one?
I am not concerned about mileage during extreme cold events - only that making the jump to an EV doesn't represent a leap back for me to cars of the 80's that manage their heating and cooling systems poorly. If the vehicle makes me miserable during cold weather events, it's not an acceptable choice to me. I'll likely try to rent one before I buy, if the responses here are positive.
