I had code C1225 pop up. After replacing the hub and sensor the light went out and most of the time the car drives normally. However, when I take a turn at moderate speeds skid control engages. Is there some kind of recalibration that needs to happen? I did not unplug the battery when replacing the parts. Also, I bought the washer below after reading it could be the issue but there wasn’t one to replace so since I didn’t know where to put it and I did not install.
One complicating factor. The day before doing this work I had 2 new tires put on the back and alignment done. On the way home it felt like something was loose and but upon checking there wasn't. Though I didn't notice it at the time it is likely the anti skid was causing this but I didn't see the light coming on. It could be because the ABS light was on I wasn't getting a notification when the system was intervening.
The car feels mostly normal when I turn off the traction and skid control (it feels like it never completely turns off?), though the rear end does feel a bit more loose than normal and not as confidence inspiring.
Any help would be greatly appreciated. Thanks
