3M makes a adhesive film (that's professionally cut/installed) as well. I haven't put it on my volt yet, but I'm seriously considering it.I had X-Pel clear paint protectent film done on the whole hood, front, partial quarter-panels, mirrors, A-pillars and roof leading edge.
Not cheap, but I hate having paint chips and digs. Turned out great.
+1 on the 3M product.I have the 3M clear bra film on my Volt and the Xpel on my Bolt. Having both, the 3M is my preference. The Xpel is thin and more fragile compared to the 3M. After only 1 year and 15k miles, the XPel on my Bolt is way more damaged (ripped, bug impact blemishes , pebble "holed") than the 3M on my Volt after 7 years and 97k miles.
I will demand the 3M product the next time.
I just looked up Scotchgard Pro on ebay; But i am surprised one seller is selling for 370 and the other is selling for 175. Both says Scotchgard Pro. How much did you spend?+1 on the 3M product.
There is a Scotchgard and Scotchgard Pro which I believe is a bit thicker than the standard Scotchgard. I have the Pro and it is excellent. Not too terrible to install yourself either if you have a bit of patience and enjoy that sort of thing. They have custom pre-cut kits on eBay for a couple hundred bucks that cover almost the entire front end.
It took 2 guys three hours to do my Volt and they do this day in day out for a living.And how hard was it to install it yourself? I saw some videos--it looks like it requires a lot of patience to spray the liquid and get the bubbles out, etc.
There is quite a range of price on the kits. Try to compare exactly which areas the kits cover - some include the mirror caps, headlights, etc. Also, try to compare how far up the hood the material covers - 12", 18" etc. Also watch out for Pro vs non-Pro Scotchgard.I just looked up Scotchgard Pro on ebay; But i am surprised one seller is selling for 370 and the other is selling for 175. Both says Scotchgard Pro. How much did you spend?
Cool. Thanks for the info and tips!There is quite a range of price on the kits. Try to compare exactly which areas the kits cover - some include the mirror caps, headlights, etc. Also, try to compare how far up the hood the material covers - 12", 18" etc. Also watch out for Pro vs non-Pro Scotchgard.
Some areas are pretty easy to do like the hood because they are pretty flat. Other areas like the mirror caps are tougher because you have to tack and stretch the material around curves. There are tons of youtube videos on how to do it that helped me a lot. It's mostly patience and you will get the hang of it. I put some on simple areas first like my door sills to get the hang of it. Also make sure to get the yellow squeegee tool as well as spray bottles for the alcohol and baby shampoo (yes really). Follow 3Ms instructions to the tee about application.
The front of the car is complex but the kit makes it easier since you don't have to cut anything (you may have to cut little holes for the parking sensors). Having an assistant and a clean environment is helpful. Peeling the material off the backing is the toughest part because it is so easy for it to stick to itself and get ruined. I actually bought a big wide piece and did my own cuts with a razor blade. Cheaper but not for the faint of heart because you MUST stay away from the paint because it would be totally possible to slice the finish if you're not careful. If I had to do it over again I'd get the kit as I think it'd be much less stressful. I plan to replace it in a couple of years since I'm worried it could be tough to remove if it ever hardens or something. Overall, I am very happy with the results (people can't even tell it's there even up close) and the money I saved doing it myself. I am sure a pro would do a better job but I don't think it's be $500 better or anything.
Hope that helps and good luck!
