Does anyone have access to the service manual, and can tell us the torque values for:
1. Front Caliper Mounting Bolts. I believe these might be single-use TTY fasteners that need replaced each time they are removed.
2. Front Caliper guide pin bolts. Sometimes called caliper slides.
3. Bleeder screw.
4, 5, 6 - Same items for the rear.
Also - do front and rear pistons go straight in, or do either need to be turned counter-clockwise to retract them into the caliper housing?
Thank you!
3. Bleeder screw.
Thank you!
