I took my car in this morning for what I had assumed was a bad rear wheel bearing, but instead they told me that the rear pads were worn to the metal and that they'd damaged the rotors, so both would need to be replaced. The front brakes were badly corroded, but still plenty of pad left and not damaged, so they're just going to clean them up. I've seen other's posts here about seized rear brakes, so this case is uncommon but not unheard of. I have done the occasional firm braking downhill to try to clean things up, but apparently it wasn't enough here in the salt belt.
I'm out of the bumper to bumper warranty so I'm looking at about $450 to replace rear brakes I never use on a car with 60k miles, but obviously this is not the result of normal brake wear. I tried calling the Volt Advisor line, who in turn talked to the dealership, but they weren't able to save me anything.
I've heard of GM occasionally covering or discounting repairs out of warranty under a goodwill policy, and this seems as good a candidate as any, but am unsure where else to go with this now. Has anyone heard of someone having success getting this sort of thing covered, and how they did it?
