OK, I already have another set of wheels and tires mounted on my Bolt.
Here are most of the specifics:
5 X 105mm. is the correct dimension, and the hub hole diameter is identical to the late model Cruze wheels, which I believe is also identical to the hub hole diameter on the late model Volts. And, clearance seems to be fine with oem Cruze wheels, as far as the brake caliper and strut clearances.
Now for the even cooler stuff:
There is an aluminum five spoke 16" X 6.5" Cruze oem wheel that fits perfectly, if you want to use 16" wheels that look nice for your winter tires. That is the ones I used for mine, and they cost $105 each on Ebay.
Also, this size wheel (1" smaller than oem, but same width) is legal in all SCCA stock classes for autocrossing, and with a set of low profile Bridgestone Potenza R71 or other high performance tires, you end up with a Bolt that is about 1" lower, corners flatter, has about 8-10% better acceleration and braking with no suspension changes.
It will, of course mess up your speedometer and odometer values by that same percent, and instead of 238 miles of average range, you will actually get about 220.
But, let me tell you, it probably drops the Bolt acceleration from 0-60 mph down to 6 seconds flat.
But, the good news is that those who already have winter tires for the gen2 Volt are already set, the same 16" or 17" wheels and tires should work great on a Bolt. And you all know what aftermarket wheels will fit the Bolt now.
