If the battery pack is near full state of charge... regen is diminished to almost nothing.I did not see an increase in regen using the paddle in L whatsoever. I believe the car might have had a faulty switch or something.
DOH!!! Yes, it was fairly well charged.If the battery pack is near full state of charge... regen is diminished to almost nothing.
If you "burn off" a few miles, you'll have max regen available once again.
To answer the original question, pulling the paddle adds additional regen even when driving in "L" mode.... no question about it- as long as you're not near max state of charge.
They got you covered... the auto breaking won't let you hit the car in front of you... I could see someone expecting to get regen, not getting it, and rear-ending someone. Next thing you know GM is getting sued...
You can test the auto braking safely. I saw a show that created dummy cars from a light wood frame covered with cardboard, then painted to look like a rear end with fake lights. Choose a safe street or parking area that has space to run and test. Set up the dummy with space behind it. Then run at it at 30 MPH or better. If your car stops, it passed the test. But if it doesn't, the dummy will fall over, and running the car over the cardboard will not damage the test car or its bumper.They got you covered... the auto breaking won't let you hit the car in front of you
I'm not going to test it like I tested the lane keeper (it worked perfectly by nudging the Bolt back into the lane), but I assume the auto breaking will work perfectly too.
You can rent Bolts by the hour from Maven in Los Angeles. Get some realistic store mannequins and make You Tube history!You can test the auto braking safely. I saw a show that created dummy cars from a light wood frame covered with cardboard, then painted to look like a rear end with fake lights. Choose a safe street or parking area that has space to run and test. Set up the dummy with space behind it. Then run at it at 30 MPH or better. If your car stops, it passed the test. But if it doesn't, the dummy will fall over, and running the car over the cardboard will not damage the test car or its bumper.
You can do the same with dummy pedestrians and test the pedestrian detection system.
Except to get "auto breaking" you need to change trims to the Premier and add an infotainment package...Also, unless I missed a news article, the point of it is a last resort/soften the blow functionality vs autonomous braking...Perhaps under certain conditions such as single digit speeds it could indeed prevent a collision, but it wasn't designed to be used as an ACC replacement...They got you covered... the auto breaking won't let you hit the car in front of you
I sure as heck hope not! I don't want a car that breaks automatically, I want one that brakes automatically.I'm not going to test it like I tested the lane keeper (it worked perfectly by nudging the Bolt back into the lane), but I assume the auto breaking will work perfectly too.
Are they actually available yet? I saw the announcement, but when I called Maven they couldn't say whether or not...You can rent Bolts by the hour from Maven in Los Angeles. Get some realistic store mannequins and make You Tube history!
I signed up, it showed the Bolt on the app, but it was hourly only, so I didn't do it. No daily rates.Are they actually available yet? I saw the announcement, but when I called Maven they couldn't say whether or not...
