One of the concerns we've heard expressed by some is the initial disabling of regenerative braking immediately after charging, when the owner lives (or charges) at near the top of steep grade.
Since with a fully charged battery there is no place to store the energy, the only option either to permit the system to brake the car using hydraulic/friction brakes, OR to manually stop charging so as to leave some room for the energy produced by regen during that initial descent.
Well the Bolt employs a a charging system feature that looks to mitigate this occurrence.
Hill-Top Reserve , when engaged in charging options and will automatically stop the charge slightly short of a full charge so that regen will be immediately available.
This feature also integrates with the Location Based Charging feature, allowing the system to be configured so it is enabled when at home (On - Home Only) or away (On - Away Only)
Problem Solved!
WopOnTour
Problem Solved!
WopOnTour
