I drive mostly in open country in a mountainous and curvy terrain and sometimes have long slopes. The 'D' regen in the Bolt apparently has a higher relative level compared to my 2013 Volt. And that level was comparable to most resistance from a standard automatic. The point being that I could drift down long slopes with the Volt and maintain momentum at that level of regen. If I gained a little more speed than was legal I might tap the brake a bit and increase regen. The Bolt slows down too much to maintain momentum even on fairly steep grades, and I value momentum more than regen much of the time, and is more efficient. I don't really want to shift into 'N' but find myself doing it at times, and I don't want to pay attention to 'feathering' as an un-needed distraction. . A slight reduction in regen would be ideal and more natural. With several ways to increase regen if needed I don't think the level of regen in 'D' is warranted.
I wouldn't mind if the paddle modulated regen, and it would be a MUCH more useful feature if it did, but that's irrelevant to my first point as I don't think the paddle issue can be resolved at this point. It's uncomfortable for those not driving as it's not a familiar routine in other cars except where the driver is kind of erratic on the brake. Passengers look up and around thinking there is some issue they should be aware of. And I 'get' 'L' in urban driving.
