1 - 3 of 3 Posts
Is there anyway to reset the Infotainment system while the car is running? The Bluetooth on my 2014 Volt has always been temperamental, sometimes it will be greyed out and not work again until I completely restart the car (stop, power down, open door, close door, restart). Seems like there should be an easier way to reset this.
FYI, this should be moved to the Gen I forum.
As far as I know, the way the Bluetooth in the Volt works is that it will only attempt to connect to a device within the first few minutes of turning on. At least that's how it appears to me. I know if the Bluetooth on my phone is off when I first get in, then I turn it on later, it will not connect to the car until I restart the car.
· Super Moderator
2012 Std w Nav
The little pairing dance where you delete the device from the car and re-pair it seems to ... er... repair... a lot of these kinds of issues. Prior phone needed this done a couple of times before it finally settled down and stayed connecting regularly.
1 - 3 of 3 Posts
